Fujifilm X-T5
Тема в разделе "Камеры Fuji серии X со сменной оптикой", создана пользователем George_N, 1 ноя 2022.
  1. George_N
    Камера анонсирована.
    Официальный пресс-релиз: https://www.fujifilm.com/us/en/news...film-introduces-xt5-mirrorless-digital-camera
    Страница камеры на сайте Фуджи: https://fujifilm-x.com/global/products/cameras/x-t5/
    Старт продаж 17 ноября.
    Спецификации:
    Number Of Effective Pixels:
    – 40.2 millions pixels
    Image Sensor:
    – 23.5mm x 15.6mm (APS-C) X-Trans CMOS 5 HR with primary color filter
    Sensor Cleaning:
    – System Ultra Sonic Vibration
    File Format (Still)
    – JPEG-Exif Ver.2.32, HEIF-4:2:2 10bit, RAW-14bit RAW (RAF original format), TIFF-8bit / 16bit RGB (In-camera Raw Conversion Only)
    Number Of Recorded Pixels
    – L: (3:2) 7728 x 5152 (16:9) 7728 x 4344 (1:1) 5152 x 5152 M: (3:2) 5472 x 3648 (16:9) 5472 x 3080 (1:1) 3648 x 3648 S: (3:2) 3888 x 2592 (16:9) 3888 x 2184(1:1) 2592 x 2592
    Lens Mount
    – FUJIFILM X mount
    Sensitivity Standard Output
    – Still: Auto1/ auto2/ auto3/ ISO125-12800 (1/3 Step)
    – Movie: Auto/ ISO125-12800 (1/3 Step)
    Sensitivity Extended Output
    – Still: ISO80/I SO100/ ISO25600/ ISO51200
    – movie: ISO25600
    Exposure Control
    – TTL 256-zone metering/ Multi/ Spot/Average/ Center Weighted
    Exposure Mode
    – P (Program AE)/ A (Aperture Priority AE)/ S (Shutter Speed Priority AE)/ M (Manual Exposure)
    Exposure Compensation
    – STILL: -5.0EV-+5.0EV (1/3EV step)/ MOVIE: -2.0EV-+2.0EV (1/3EV step)
    Image Stabilizer Mechanism
    – Image sensor shift mechanism with 5-axis compensation
    Image Stabilizer Compensation Effect
    – Up to 7.0 stops (based on CIPA standard). Pitch/yaw shake only, with XF35mmF1.4 R lens attached.
    Digital Image Stabilization
    – Yes, movie mode only
    Image Stabilizer Is Mode Boost
    Shutter Type
    – Focal Plane Shutter
    Shutter Speed Mechanical Shutter
    – P mode: 30 sec to 1/8000
    – A mode: 30sec to 1/8000
    – S/M mode: 15min to 1/8000
    – Bulb mode: up to 60min
    Shutter Speed Electronic Shutter
    – P mode: 30 sec to 1/180000
    – A mode: 30sec to 1/180000 S/M mode: 15min to 1/180000 Bulb mode: 1sec Fixed
    Electronic Front Curtain Shutter Speed
    Mechanical + Electronic Shutter Speed
    – S/M mode: 15min to 1/180000
    E-Front + Mechanical Shutter Speed
    E-Front+Mechanical+Electronic Shutter
    – Bulb mode: 1sec Fixed Shutter Speed
    Shutter Speed Movie
    – 6.2K: 1/8000 to 1/24
    – DCI 4K/4K: 1/8000 to 1/4 sec.
    – FHD: 1/8000 to 1/4 sec.
    Synchronized Shutter Speed For Flash
    – Mechanical Shutter: 1/250sec. or slower
    – Electronic Shutter: 1/125sec. or slower
    Continuous Shooting
    – Electronic Shutter Approx. 20fps (1.29x Crop) (JPEG: 168 frames ,Compressed RAW: 72, Lossless Compressed RAW 41, Uncompressed RAW: 37 frames, Uncompressed RAW +JPEG: 23 frames)
    – Electronic Shutter Approx. 13fps (1.29x Crop) (JPEG: 1000+frames ,Compressed RAW: 104, Lossless Compressed RAW: 53, Uncompressed RAW: 23 frames, Compressed RAW + JPEG: 56, Lossless compressed RAW + JPEG: 44, Uncompressed RAW + JPEG: 23)
    – Electronic Shutter Approx. 10fps (1.29x Crop) (JPEG: 1000+ frames ,Compressed RAW: 1000+, Lossless Compressed RAW 70, Uncompressed RAW: 25 frames, Compressed RAW +JPEG: 72 frames, Lossless compressed RAW + JPEG: 53 frames, Uncompressed RAW + JPEG: 23 frames)
    – Mechanical Shutter Approx. 15fps (JPEG: 119frames ,Compressed RAW: 39 frames, Lossless Compressed RAW 22 frames, Uncompressed RAW: 19 frames, Compressed RAW + JPEG 27 frames)
    – Mechanical Shutter Approx. 10fps (JPEG: 1000+ frames ,Compressed RAW: 56 frames, Lossless Compressed RAW 29 frames, Uncompressed RAW: 19 frames, Compressed RAW + JPEG: 34 frames)
    – Mechanical Shutter Approx. 7.0fps (JPEG: 1000+ frames ,Compressed RAW: 1000+ frames, Lossless Compressed RAW 33 frames, Uncompressed RAW: 20 frames, Compressed RAW + JPEG: 45 frames, Lossless compressed RAW + JPEG: 22 frames, Uncompressed RAW + JPEG: 20 frames)
    – Electronic Shutter Approx. 20fps (1.29x Crop) (While half press 20 frames ,After full press 140 frames)
    – Electronic Shutter Approx. 13fps (1.29x Crop) (While half press 13 frames ,After full press 300 frames,)
    – Electronic Shutter Approx. 10fps (1.29x Crop) (While half press 10 frames ,After full press 370 frames,)
    – Electronic Shutter Approx. 13fps (While half press 13 frames ,After full press 70 frames,)
    AE Bracketing
    – AE Bracketing (Frames: 2, 3, 5, 7, 9 Step: by 1/3EV step, up to +/-3EV steps)
    – Film simulation bracketing (Any 3 types of film simulation selectable)
    – Dynamic Range Bracketing (100%, 200%, 400%)
    Focus Mode
    – Single AF/ Continuous AF/ MF
    Focus Type
    – Intelligent Hybrid AF (TTL contrast AF / TTL phase detection AF)
    Focus Low-Light Performance
    – Contrast: -4.0EV
    – Phase Detection: -7.0EV
    AF Frame Selection
    – Single point AF: 13 x9/ 25 x17 (Changeable size of AF frame) Zone AF: 3 x3/ 5 x5/ 7 x7 from 117 areas on 13 x9 grid Wide/Tracking AF AF-S: Wide/ AF-C: Tracking
    All
    White Balance
    – Auto (White Priority, Auto, Ambience Priority)/ Custom1 – 3/ Color Temperature Selection (2500k-10000k)/ Preset Daylight, Shade, Fluorescent Light-1, Fluorescent Light-2, Fluorescent Light-3, Incandescent Light, Underwater
    Self-Timer
    – 10sec./2sec.
    Interval Timer Shooting
    – Yes (Setting : Interval, Number of shots, Starting time, Interval timer shooting exposure smoothing)
    Flash
    – EF-X8 Guide Number approx. 11 (ISO200 m) / approx. 8 (ISO100 m)
    Flash Sync Mode
    – EF-X8: 1st Curtain/ 2nd Curtain
    – Shoe Mount Flash: 1st Curtain/ 2nd Curtain AUTO FP (HSS) Synchronized terminal: 1st Curtain/ 2nd Curtain.
    Flash Mode
    – TTL (TTL Auto / Standard / Slow Sync. ) / Manual / Commander / Off Shoe Mount Flash TTL (TTL Auto) / Standard / Slow Sync. ) / Manual / Multi
    Hot Shoe
    – Yes (Dedicated TTL Flash compatible)
    Viewfinder EVF
    0.5 inch approx. 3.69 million dots OLED Color Viewfinder
    Coverage of viewing area vs. capturing area: approx. 100%
    Eyepoint: approx. 24mm (from the Rear End of the camera’s Eyepiece)
    Diopter adjustment: -5-+3m-1
    Magnification: 0.80 x with 50mm lens (35mm equivalent) at infinity and Diopter set to -1.0m-1
    Diagonal angle of view: approx. 40 Degree (Horizontal angle of view: approx. 32 Degree ) Built-in eye sensor
    LCD Monitor
    3.0 inch Tilt-Type (Three Direction) Touch Screen Color LCD Monitor
    Aspect Ratio 3:2
    Resolution: Approx. 1.84 million dots
    Touch Screen Shooting Mode
    Shooting, AF, Focus Area, OFF, Double Tap Setting (ON/OFF), Touch Function Setting (ON/OFF), EVF Touch Screen Area Setting
    Touch Screen Playback Mode
    Swipe, Pinch-in / Pinch-out, Double-tap, Drag
    File Format (Movie)
    HEVC/ H.265: Audio: Linear PCM / Stereo sound (24bit / 48KHz sampling) MPEG-4, AVC/ H.264: Audio: Linear PCM / Stereo sound (24bit / 48KHz sampling)
    MP4, MPEG-4, AVC/ H.264: Audio: AAC
    Movie Compression
    All Intra/Long-GOP
    File Size / Frame Rate / Recording Time
    6.2K (16:9) – 6240 x3150: 29.97p/ 25p/ 24p/ 23.98p 360Mbps/ 200Mbps/ 100Mbps/ 50Mbps
    DCI 4K (17:9) – 4096 x2160: 59.94p/ 50p/ 29.97p/ 25p/ 24p/ 23.98p 360Mbps/ 200Mbps/100Mbps/50Mbps
    4K (16:9) – 3840 x2160: 59.94p/ 50p/ 29.97p/ 25p/ 24p/ 23.98p 720Mbps/ 360Mbps/ 200Mbps/ 100Mbps/ 50Mbps
    Full HD (17:9) -2048 x1080: 59.94p/ 50p/ 29.97p/ 25p/ 24p/ 23.98p 360Mbps/ 200Mbps/ 100Mbps/ 50Mbps
    Full HD (16:9) – 1920 x1080: 59.94p/ 50p/ 29.97p/ 25p/ 24p/ 23.98p 360Mbps/ 200Mbps/ 100Mbps/ 50Mbps
    Full HD High speed rec. (17:9) – 2048×1080: 240p/200p/ 120p/ 100p 360Mbps(recording)/ 200Mbps(recording)
    Full HD High speed rec. (16:9) – 1920×1080: 240p/200p/ 120p/
    100p/360Mbps(recording)/ 200Mbps(recording)
    Film Simulation Mode
    19 modes (PROVIA/Standard, Velvia/Vivid, ASTIA/Soft, Classic Chrome, PRO Neg.Hi, PRO Neg.Std, Classic Neg., Nostalgic Neg., ETERNA Cinema, ETERNA BLEACH BYPASS, ACROS, ACROS + Ye Filter, ACROS + R Filter ACROS + G Filter, Black & White, Black & White + Ye Filter, Black & White + R Filter, Black & White + G Filter, Sepia)
    Clarity Setting
    +/-5 steps
    Monochromatic Color
    Yes
    Grain Effect
    Roughness Strong, Weak, Off, Size Large, Small
    Color Chrome Effect
    Strong, Weak, Off
    Color Chrome Blue
    Strong, Weak, Off
    Smooth Skin Effect
    Strong, Weak, Off
    Dynamic Range Setting
    AUTO, 100%, 200%, 400%
    ISO restriction (DR100%: No limit, DR200%: ISO320 or more, DR400%: ISO640 or more)
    Dynamic Range Setting (Movie)
    100%, 200%, 400%
    ISO640 or more)
    Advanced Filter
    Toy camera
    Miniature
    Pop color
    High-key
    Low-key
    Dynamic tone
    Soft focus
    Partial color (Red / Orange / Yellow / Green / Blue / Purple)
    Wireless Transmitter Standard
    IEEE802.11a/b/g/n/ac (standard wireless protocol)
    Wireless Transmitter Encryption
    WEP/WPA/WPA2 mixed mode
    Wireless Transmitter Access Mode
    Infrastructure
    Bluetooth Standard
    Bluetooth Ver. 4.2 (Bluetooth low energy)
    Bluetooth Operating Frequency
    2402 – 2480MHz
    Terminal – Digital Interface
    USB Type-C (USB3.2 Gen2x1)
    Terminal – Hdmi Output
    HDMI connector (Type D)
    Terminal – Others
    3.5mm, stereo mini connector (Microphone), 2.5mm, Remote Release Connector, Hot shoe, Synchronized terminal
    Power Supply
    NP-W235 Li-ion battery (included)
    Battery Life For Still Images
    Economy Mode Approx. 740 frames, Normal Mode Approx. 580 frames
    Actual Battery Life For Movie Capture
    6.2K Approx. 90min. (29.97p)
    4K Approx. 80min. (59.94p)
    Full HD Approx. 90min. (59.94p) F
    ull HD Approx. 100min. (120P)
    Continuance Battery Life
    6.2K Approx. 130min. (29.97p)
    4K Approx. 130min. (59.94p)
    Full HD Approx. 150min. (59.94p) (For Movie Capture)
    Operating Temperature
    -10 Degree C-40 Degree C
    Operating Humidity
    10% – 80% (no condensation)
    Starting Up Period
    Approx. 0.49sec.
    Battery Info
    Required, included
    Battery Material
    Lithium ion
    Battery Type
    NP-W235
    Battery Quantity
    Dimensions (W x H x D)
    129.5 x 91 x 63.8mm
    Minimum Depth
    37.9mm
    Weight
    Including battery and memory card: 557g (Approx.) Excluding battery and SD memory card: 476g (Approx.)
    #1 George_N, 1 ноя 2022 в 10:19 Fujifilm X-T5
  2. Vladimir Fedotov
    Годная камера. Но у меня нет зуда,- подожду, пока пена уляжется))) Мне ХТ фактор ближе чем ХН, и радует, что они корпус даже сделали в сторону уменьшения от ХТ4, у которой мне и экран не подходит- а тут прямо ХТ3 протюнингованая))
  3. George_N
    Точно. Размерчик даже чуть меньше Т3, ближе к Т1, при том, что батарея крупнее и стаб есть. И вес снизили против Т4, на каких-то 20 гр. тяжелее, чем Т3. Просто классика Х-Т серии.
  4. Thailer
    Thailer Старейшина
    15 июл 2020
    Пока не понял, Фуджи в новых камерах наконец-то завезли трекинг в видео, как во всех нормальных современных гибридах или опять эпик фэйл?
  5. George_N
    Экран другой: 1.84 Мп против 1.6. А по Эви нашли такой компромисс: матрицу видоискателя оставили, как в Т3/Т4 - 3.7 Мп, а оптику видоискателя взяли от Н2 - увеличение 0.8х.
    #5 George_N, 1 ноя 2022 в 14:45 Fujifilm X-T5
  6. ArcticFox
    ArcticFox Старейшина
    3 мар 2015
    Ура! Нормальный экран!
    А то уж думал больше не будут таких делать
    Shishkin_Dmitry, Vital и cyxapuk нравится это.
  7. George_N
    Раз уж запустили линейку Н2/S как топовые и именно гибридные камеры с полно-поворотным экраном, то в Т5 можно вернуться к классике.
  8. Серж[42]
    Что вам не нравится экран в хт4? ну был хт3, сейчас 4, я вообще не обламываюсь, даже вот капельки облома нету))) А еще нравится, что его можно просто закрыть, это же отлично для траспортировки, или просто когда несешь на шее. По мне экран как экран, свою функцию выполняет.
  9. Андрей_Б
    получилась сборная модель из корпуса, очень напоминающего Х-Т3 (габариты, экран, крышки разъемов и передняя часть, где надпись Fujifilm), с матрицей от Н2..
    но видоискатель оставили как у Т4 (может такой же и на Т3 был, точно не помню).
    не поставили разъем для наушников (опять как в Т4 через переходник).
    и нет больше батарейного блока..
  10. СергейНН
    СергейНН Старейшина
    1 янв 2016
    И горделивой надписи Made in Japan судя по фото тоже похоже не будет. Всё теперь делают в Китае
  11. George_N
    У Т3 и Т4 видоискатель идентичный. Здесь же взяли оптику видоискателя от Н2, увеличение больше.
    Так Т4 уже там делалась.
  12. Thailer
    Thailer Старейшина
    15 июл 2020
  13. George_N
    Сравнение размеров с Т4.
    И с Т1.
    Andre ViKi и Николай И. нравится это.
  14. Spasov_Konstantin
    И как с этой классикой нормально фотографировать когда у меня 97 процентов фото вертикальные от пояса? Вообще новые камеры упёрлись в свой потолок, как и смартфоны. Производители топчатся на месте. Ладно хоть у других производителей автофокусом можно пользоваться, так фудж даже это не подтянул нормально. Ну как так? Расстройство.
    P.s: Но всё равно люблю своего гадкого утенка, за плёночки и красивый лук :D
    graph и фарш нравится это.
  15. George_N
    Найти себе камеру под стиль съемки "97 процентов фото вертикальные от пояса". И с автофокусом.
  16. VPozyvnoy
    VPozyvnoy Старейшина
    8 окт 2020
    @Spasov_Konstantin, а что с авто фокусом не так у Fujifilm? Я так понимаю вы протестировали некоторое количество других камер и камеры Fujifilm в этой категории самый плохой результат?
    Просто я другие камеры не пользовал а пользовался авто фокусом в следящем режиме при съемках машин в ночи. И результат по мне отличный.
    Да, еще наводился в телевике на птиц и очень даже хорошо;) Не, ну может быть я не знаю что есть еще лучше?
    #16 VPozyvnoy, 2 ноя 2022 в 16:52 Fujifilm X-T5
  17. Серж[42]
    А по цене то что? вроде как слишал 1699 баксов.
  18. Alexxp
    Alexxp Старейшина
    24 июл 2015
    А у меня как раз разбился любимый X-T2. Теперь точно придётся ждать продаж X-T5. До сих пор имею X-Т1, который не продаю и не продам.
    graph, cyxapuk, Валдис и ещё 1-му нравится это.
  19. Thailer
    Thailer Старейшина
    15 июл 2020
  20. George_N
