День приятных новостей. Самьянг обновил линейку своих объективов, теперь при выпуске плотно учитывает фуджи байонет. Прибавились 16/2, 300/6.3 и Тилт-Шифт TS-24mm/3.5, готовится к выпуску 10/2.8. С учетом пикинга мануfльными стеклами становится интересней пользоваться. Подробная информация: 24 TS Specification TILT/SHIFT LENS 1:3.5 24mm ED AS UMC Aperture Range F3.5 ~ 22 Optical Construction 16 Element in 11 Groups (2 ASPHERICAL LENS) Angle of View 59.9?(APS-C) Minimum Focusing Distance 0.2m (0.66ft) Filter Size Ф82mm Length 107 ~ 139 mm Maximum Diameter Ф86mm Weight 646 ~ 745g Mount Canon EOS, Canon M, Nikon, Pentax, Sony, Sony-E, FUJIFILM X, Samsung NX, Four-thirds, Micro Four-thrids Lens Coating Multi-coating Data sheet: http://www.syopt.co.kr/common/pdf/TS f=24mm.pdf 16/2 Specification 1:2.0 16mm ED AS UMC CS Aperture Range F2.0 ~ 22 Optical Construction 13 Element in 11 Groups (2 ASPHERICAL LENS) Angle of View 83.1?(APS-C) Minimum Focusing Distance 0.2m (0.66ft) Filter Size Ф77mm Length 86.9 ~ 115.7 mm Maximum Diameter Ф83mm Weight 571 ~ 615g Mount Canon EOS, Canon M, Nikon, Pentax, Sony, Sony-E, FUJIFILM X, Samsung NX, Four-thirds, Micro Four-thrids Lens Coating Multi-coating Data sheet http://www.syopt.co.kr/common/pdf/f=16mm.pdf 300/6.3 Specification Reflex 1:6.3 300mm ED UMC CS Aperture Range F6.3 FIXED Optical Construction 9 Element in 9 Groups Angle of View 5.4?(APS-C) Minimum Focusing Distance 0.9m (2.95ft) Filter Size Ф25.5mm (REAR) Length 72.6 ~ 74.1 mm Maximum Diameter Ф64.5mm Weight 311 ~ 318g Mount Canon MS, Sony-E, FUJIFILM X, Micro Four-thrids Lens Coating Multi-coating Data Sheet http://www.syopt.co.kr/common/pdf/f=300mm.pdf 10/2.8 Specification 1:2.8 10mm ED AS UMC CS Aperture Range F2.8 ~ 22 Optical Construction 14 Element in 10 Groups (2 ASPHERICAL LENS) Angle of View 109.5?(APS-C) Minimum Focusing Distance 0.25m (0.82ft) Filter Size NONE Length 76.7 ~ 105.5 mm Maximum Diameter Ф86mm Weight 710 ~ 740g Mount Canon EOS, Canon M, Nikon, Pentax, Sony, Sony-E, FUJIFILM X, Samsung NX, Four-thirds, Micro Four-thrids Lens Coating Multi-coating Data Sheet http://www.syopt.co.kr/common/pdf/f=10mm.pdf
300-ка уже даже продается. Не у нас правда. При желании можно найти кадры с нее - не просто ужас, а ужас-ужас. Ни резкости, ни контраста.... что в купе с отвратительным боке зеркального объектива.... вобчем хотел взять поиграть, но после таких образцов даже в руках вертеть не интересно.
http://www.samyang.pl/index.php/en/2013/kwiecie/137-samyang-tilt-shift-24mm-w-sprzeday-od-poowy-maja http://www.ephotozine.com/article/samyang-t-s-24mm-f-3-5-ed-as-umc-lens-review-21853 тут есть семплы с 24TS
Не может быть такого. Если разный рабочий отрезок у разных байонетов, то соответственно нужно и по разному размещать линзы. А про вес и размеры читайте в даташитах которые вы выложили.
А. вы имели ввиду - самые тяжелые в пределах вилки в 30-50гр ) а это вполне логично. у фуджи самый маленький рабочий отрезок. т.к. оптический узел одинаковый везде(и находится на одном и том же расстоянии от матрицы) то эту разницу в рабочих отрезуках нивелируют размерами и выходящим увеличенным весом хвоста. у кого-то хвост покороче и легче, у кого-то длинней и логично, что тяжелей. как раз в этой вилке в 50гр для полукилограмового стекла.
