Как вам новая камера?
  1. Отлично, надо брать
    86 голосов
    39,4%
    114 голосов
    52,3%
    18 голосов
    8,3%
  1. АртёмКа
    еще про зерно в новой прошке:
    To achieve the ACROS like texture, the film-like "graininess" is another important element.
    To be specific, ACROS mode has a completely different noise reduction algorithm from other modes. The "graininess" of the silver-halide films are what we see as "noise" in the digital data. For color images, they are the unwanted noise, but in the monochrome images, it becomes an important texture. Turning the noise into grain-like texure is what makes ACROS unique and different.
    Other manufacturers are also implementing the idea of creating "graininess" to enhance the texture. FUJIFILM is not the only brand doing this. You can find "Grain" filter in the readily available photo processing software, and many monochrome photographers add "grain" to acieve the monochrome film like effect.
    Most of them try to achieve this by adding "grain-like element" to the original image. They simply add another layer of "dotted graininess" on top without changing the original photo composition. So something becomes unnatural in the process.
    "ACROS" is different.
    We developed it from the core of the image file to achieve a very complex and natural like grain expression. Optimal and different grain expressions are added to highlight and low light areas. You would not find unnatural dotted graininess in the highlight areas just like how the monochrome film behaves. In the low light area, you would see the graininess just like how it would appear with the monochrome film. There are undulating grain within the picture. And it adds depth like no other.
    ACROS also changes the output of graininess depending on the sensitivity setting. As the sensitivity gets higher, stronger grain effect becomes visible, just like the film.
    We have seen the advancement of high S/N ratio of digital cameras, but people generally want to take photos with lowest sensitivity possible. But with ACROS, it may be a different story.
    The unique grain effect, which becomes apparent at the higher ISO sensitivity. You can intentionally set the sensitivity high to enjoy the effect.
    http://fujifilm-x.com/en/x-stories/the-newest-film-simulation-acros/
    Фуджоиды крутые! Многие говорили, что шум х-транса похож на плёночное зерно, а фуджиманы его действительно превратили в зерно :)
    ok.vova и monktsp нравится это.
  2. monktsp
    monktsp Постоялец
    14 авг 2015
    Первые 4 пункта заставляют меня нервничать.
    Я не хочу такую большую камеру, я хочу X-T20/X-T2.
    Но первые4 фичи хочется не через годы (или когда там выпустят новые камеры), а через месяцы.
    Что вы со мной делаете...
    Конечно, надо потестить камеру, чтобы понять ее необходимость окончательно. В марте может появится в прокатах уже
  3. af1975
    af1975 Старейшина
    15 май 2015
    Узбогоин не поможет?
  4. af1975
    af1975 Старейшина
    15 май 2015
    Собсна, вот что он написал:
    "Совершенно не согласен с большинством мнений. Объектив использую около года это ни разу не макрик, хороший портретник и отличный предметник для натюрмортов. Рисунок в нерезкости чем-то напоминает, скорее, сонарчики, чем-то иногда похож по рисунку на макрик Токина 100 (вот только эта токина реальный макрик) такая же акварель в боке. Очень хорошо выдает отенок. Простенько, но со вкусом. Боке очень мягкое, но излишне моет удаленные объекты. Хорошо годится для крупных портретов, но из-за избыточной резкости прет "дерматология". Т.е. снимкам нужен легкий блур.
    Макриком его обозвали в маркетинговых целях ибо в системе макрик должен быть, а он может фокусироваться на небольших расстояниях.
    Для макро ни разу не годится т.к. у него есть один косяк - на близких дистанциях на закрытой диафрагме по центру возникает паразитическая засветка с тотальной потерей резкости и контраста по центру (основными факторами ее вызывающими является боковой рассеяный свет и контрастный фон (боковой рассеяный для макро самый важный)."
    Даже если принимать безоговорочно как истину в последней инстанции, гуру не исключает предметку, а даже наоборот.
    А если воспринимать не как гуру, то надо самому пробовать. А по ттх более подходящего, повторюсь, в системе нет.
  5. gromoboy
    gromoboy Старейшина
    16 май 2014
  6. af1975
    af1975 Старейшина
    15 май 2015
    У Вас он, вроде, есть?
  7. gromoboy
    gromoboy Старейшина
    16 май 2014
    Да есть ) дает 1:1 картинку очень резкий контрастный - букашки таракашки с рук снимаются я даже вроде выкладывал если не выкладывал вот не самое лучшее исполнение но понять можно. С рук, без вспышек итд - там ньюанс надо очень близко к обьекту сьемки подносить и с башмака вспышка безполезна. А так трава ветерок трава качается и присутствует микросмаз - а может руки дрожат ) + надеюсь в новой ешке быстрый и цепкий автофокус надо его на макро протестировать - а то бывает елозил иногда - проще было на минимум в ручном ставить и самому отклоняясь попадать в фокус ))[​IMG]
    SophCat, monktsp и Alex-Der-Ant нравится это.
  8. af1975
    af1975 Старейшина
    15 май 2015
    Внушительно так
  9. Velesich
    Весточка от RawTherapee пришла
  10. ok.vova
    ok.vova Активный пользователь
    StanislaVS нравится это.
  11. StanislaVS
    A что это за установка NR -2? И еще там вроде ISO 1600 и 6400 сравнивается на одной камере x100s, при чем тут XPRO2?
  12. Дiд МаZай
    Это шумодав уведен на минус 2.
  13. SirMax
    SirMax Активный пользователь
    8 июл 2015
    Я так понимаю чел объясняе что такое waxy skin.
  14. ok.vova
    В треде 2 страницы
  15. StanislaVS
    Aха-ха... до меня дошло, мужик доказывает на примерах, что у матриц X-Trans II и III поколений при одинаковых значениях ISO шумодав в камерном Jpeg настроен более агрессивно, чем в матрицах I поколения (ХPRo1 и др). Кстати очень убедительные примеры. :D
  16. Alekzandr
    Alekzandr Один из первых
    ну так про второе поколение давно известно шо так, а вот хпро2 надо еще изучать, видел в сети жипеги с нее на NR=-4 (окромя мужика из ссылки) так ощущение что вообще без шумодава
  17. StanislaVS
    А у второго поколения минимум тоже -2, как и у первого, или -4 ? Насчет -4 у третьего поколения есть подозрение, что они шкалу просто сделали более детальной, то есть -2 стало равно -4. Хотя это всего лишь предположение, нужно изучать и сравнивать ...
  18. SirMax
    8 июл 2015
    У второго тоже -2, -4 только в 3-ем
  19. Alekzandr
    не, раньше про -4 ничего не было, че это такое самому интересно
