  1. Дiд МаZай
    На Фотокине осенью покажут - раньше вряд ли.
  2. Mikhail Sidorchev
    Инсайд? )))))
  3. Kusst
    Kusst Постоялец
    2 сен 2015
  4. Kusst
    Kusst Постоялец
    2 сен 2015
    ТХ
    – 24.3MP CMOS sensor
    – Image processing engine X Processor Pro
    – Video 4K30fps. Full HD60fps
    – Video of the bit rate is 100Mbps
    – The maximum speed of the shutter is 1/8000 seconds. 1/32000 sec electronic shutter
    – Synchro speed of the flash is 1/250 seconds
    – AF 325 points can be selected intelligent hybrid phase difference AF
    – The body is in a magnesium alloy, improve the durability of the dial. Dust and water specification
    – EVF is 2.36 million dots. Refresh rate 100fps
    – 3-way tilting 3 inches 1.62 million dot LCD monitor
    – Dual SD card slot. UHS-II support
    – AF-C custom settings
    – ISO range is ISO200-12800 (RAW)
    – Wi-Fi built-in. Remote shooting correspondence. Instax Share printer support
    – 16 kinds of film simulation modes, including the ACROS
    – That can customize the settings screen “My Menu”
    – Normal / boost mode switching
    – 14bit RAW lossless compression. Camera RAW development
    – Exposure compensation +/- 5EV
    – 256-segment metering (multi-spot average, spot, center-weighted)
    – Interval Shooting
    – 13 kinds of creative filter
    – The battery is NP-W126S. The number of possible shots 350 sheets
    – 3.5mm microphone jack. 2.5mm remote terminal. USB3.0 terminal. Micro HDMI terminal
    – You can use all of Fujinon X mount lens group When the vertical position power booster grip use of the option, can use a plurality of battery at the same time, continuous shooting is speeding up, the shooting interval, shutter time lag, the image disappearance time is shortened. In addition, 4K of recording time is extended up to 30 minutes.
  5. Дiд МаZай
    Камера всех времен и народов получается :):drinkbuddy:
    rus-lis нравится это.
  6. alessandro
    Ещё бы по деньгам народной была ;)
  7. spira
    spira Старейшина
    8 фев 2014
    Фуджи предсказуемы. Начнут с $1299 за тушку, к рождеству опустят цену до $1100.
  8. IBEAR
    IBEAR Старейшина
    10 окт 2015
    Индикаторы батарей в процентах - спасибо Fuji, ты нас слышишь!
    atomadog и Дiд МаZай нравится это.
  9. atomadog
    11 авг 2014
    Откуда инфа?
  10. Velesich
    Инфа и картинка с румора.
  11. Clapotron
    atomadog нравится это.
  12. Сергей Миронов
    Да, полезная штука!
  13. Seth777
    Seth777 Активный пользователь
    2 июн 2015
    Ставрополь
    Любопытный функционал ручки: второй джойстик и режим boost.
  14. IBEAR
    IBEAR Старейшина
    10 окт 2015
    Немного свежатины.
    В четверг 7 июля ожидается анонс беззеркальной камеры Fujifilm X-T2.
    Источник опубликовал серию снимков, на которых показано не только это устройство, но и принадлежности для съемки, которые тоже будут представлены 7 числа.
    Во-первых, это вспышка EF-X500, которая в Японии будет стоить примерно $580.
    Во-вторых, рукоятки MHG-XT2 ($150) и VPB-XT2 ($370).
    Вторая рукоятка выступает дополнительным источником питания, поскольку в ней может находиться до двух аккумуляторов.
    Один АКБ в среднем гарантированно дает сделать около 350 кадров.
    На следующих снимках запечатлена камера Fujifilm X-T2.
    Ожидается, что в ходе анонса Fujifilm еще обнародует обновленный план выпуска объективов системы Fujifilm X.
    Источники: fujirumors, IXBT, digicame-info
    PavelFuji, Citizen, rus-lis и 2 другим нравится это.
  15. Дiд МаZай
    Крутотень! И всего 90К за боди - это супер!!!
  16. Citizen
    Citizen Старейшина
    20 ноя 2014
    Зато целых 150$ за рукоятку.
  17. АртёмКа
    где сказано про 90к за боди?
  18. Дiд МаZай
    На руморсах цены выложили. Если перевести по текущему курсу - порядка 90 тыщ получается.
  19. IBEAR
    IBEAR Старейшина
    10 окт 2015
    По слухам цена будет примерно такова:
    Перевод, оригинал на fujirumors.
    Fujifilm Х-Т2 цена:
    Конечно цена будет меняться в зависимости от страны где вы живете. Но позвольте мне предположить следующую закономерность для каждой страны в мире:
    Fujifilm X-Т2 будет стоить меньше, чем в Fujifilm X-Pro2 ($1699 в США – £1,349 в Великобритании – €1799 г. в большинстве стран ЕС), но больше, чем X-Т1 на момент старта продаж ($1299 в США – £1049 в Великобритании – €1299 в большинстве стран ЕС).
    Поэтому X-Т2 должен стоить:
    США: от $1400 до $1600
    ЕС: от €1400 до €1700
    Великобритания: от £1100 до £1300
    Окончательная цена?
    Ну, я думаю, все мы извлекли урок последнего времени с Fujifilm Х70, когда компания Fujifilm меняла цену несколько раз подряд перед запуском, а затем еще раз изменила цену в течение суток на предзаказ Х70!
    Так что, лучше быть осторожным, когда дело доходит до цены.
    В любом случае, X-Т2 предлагает гораздо больше новшеств по сравнению с X-Т1 (а в некоторых аспектах и по сравнению с X-Pro2), то, что цена будет ниже X-Pro2, это уже хорошая новость для меня.
  20. Kusst
    Kusst Постоялец
    2 сен 2015
