  1. vshaev
    vshaev Гость
    Вы абсолютно правильно поняли мою мысль.
  2. gan75
    gan75 Постоялец
    21 мар 2015
    Так, словоперекатывания пролистал... Как что полезное будет, свистите;)
  3. alessandro
  4. hiZis
    hiZis Активный пользователь
    4 май 2015
    Владивосток
  5. IBEAR
    IBEAR Старейшина
    10 окт 2015
    Эта музыка будет вечной... (с)
    Take a look at the crops and make your own decisions.
    LUMINAR. This is processed using MacPhun’s Luminar.
    Although I tried some moderate sharpening it only exacerbates the poor results from this raw processor.
    I hope they improve this because they have a really great interface and set of tools/filters.
    IRIDIENT DEVELOPER has been my top pick up until now and it still reigns on top for getting the utmost quality out of Fuji’s X-Trans files.
    See my section below about keeping all this in perspective. This is pixel peeping and you’re not likely to see a difference among ID, Affinity Photo, and ON1 Photo Raw when it comes to making actual prints.
    But because of versatility and workflow efficiency I prefer using ON1 Photo Raw.
    AFFINITY PHOTO does a superb job too but it takes some time to learn the program and right now isn’t compatible with very many plug-ins so not the best for an efficient workflow.
    On the positive side it is great competition for Photoshop and very inexpensive.
    ON1 PHOTO RAW 2017.0.2 My first choice. This crop shows how ON1 has made big improvements in this new version to be released February 13, 2017.
    The obvious jagged edges in the previous version are pretty much gone. It also now supports lossless-compressed Fuji raw files.
    А теперь одна хитрая особенность, две нижние фото из лайтрума и jpeg из камеры были на самом верху, потом по нарастающей нам дают фото от самого худшего к самому лучшему проявщику.
    Я разместил лайтрум и jpeg сразу за first choice. Разница есть, но даже с учетом скидки в 15%, нужен кому за 100 у.е. очередной тру проявщик?
    LIGHTROOM. This is processed in Lightroom.
    You can see it lacks detail, the bark and boat have a plastic look, and the branches and pine needles on the right have the characteristic “worm” look. Look for the OOC JPEG below and you will see similar characteristics.
    IN-CAMERA. This is from the JPEG processed in the camera.
    Like the LR processed raw file above, you can see it lacks detail, the bark has a plastic look, and the branches and pine needles on the right have the characteristic worm look.
    That said the film profiles are wonderful and you can still use the jpegs for aiding visualization, posting online, etc.
    rus-lis нравится это.
  6. Skier
    У меня вопрос к знатокам РТ:
    я запутался немного в понимании уровней wavelet.
    Кто поможет мне разобраться?
  7. gan75
    gan75 Постоялец
    21 мар 2015
    Это уж очень тонкие знатоки RT должны быть:) В принципе в wavelet тоже как в других местах - самое меньшее значение уровня 1, далее по наростающей
  8. Alekzandr
    Alekzandr Один из первых
    В общих чертах - level 1 - наитончайшие детали, 2 - тонкие ну и так далее по нарастающей, уровни смотрятся через окошечко внизу, а ползунок вверху определяет количество задействованных уровней.
    Про прочие коэффициенты - в нете есть много про вэйвлет-преобразования, RT использует вэйвлет-преобразование Добеши,
    D2-D14 это как раз его коэффициенты, какой лучше - надо пробовать на конкретных фото.
    И да - эти манипуляции выделили только нужный слой из всего изображения. Дальше уже он шарпится, шумодавится и т.д.
    Здесь краткое введение - https://paulsphotopalace.wordpress.com/2015/10/30/wavelets-in-rawtherapee-a-short-introduction/
    Перекочевало это вроде как из Гимпа, у них давно были плагины на эту тему (правда вейвлеты более простые), через этот сайт можно статейки и примеры посмотреть http://nvitr.narod.ru/index/0-8
    если поглубже - то там откуда это пришло серьезная математика используется, если интересно, вот для начала (новичков-инженеров) полезно это почитать http://techlibrary.ru/b/2k1r1j1b1u1...1f1k1c1m1f1t-1q1r1f1p1b1r1a1i1p1c1a1o1j1f.pdf
    SophCat нравится это.
  9. Skier
    Спасибо! это я читал.
    Меня интересует подробное описание вот этих параметров:
    совсем не могу понять как использовать связку Dackground и Process.. и дальше окошко
    "Laval 4", которое то активно то нет....
  10. Velesich
    Если по поводу регулировки контраста, то проще пользоваться кнопками над движками - Contrast + и -. Они делают всё правильно, по слоям.
  11. Skier
    с контрастом мне всё было понятно сразу там и вправду всё супер!
    а вот этот Background и Process то один слой то серый точёрный 0, как влияет а как остальные ....не могу понять
  12. Velesich
    Background - это установка на каком фоне показывать слои. Что такое wavelet в курсе? Картинка раскладывается в волновые ряды и они разделяются по частотам. Та область о которой вы говорите, устанавливает на сколько частей расфильтровывать картинку, как отображать слои, буде захочется посмотреть на них по отдельности, и сколько слоёв (какой диапазон частот) обрабатываются в данной сессии. У меня там навсегда установлены максимальные параметры (типа всю картинку, все планы), послойно результаты разложения не рассматриваю.
  13. Alekzandr
    Пользуясь вашим вопросом напишу небольшие подсказки для всех для освоения инструмента.
    Исходно - все по умолчанию, затем в процессе выберите One Level , станут активны окошки Level и Direction, сначала поперебирайте левелсы, затем бэкграунд (серый и черный там тривиальны, а про Остаточное изображение я боюсь не каждый из разработчиков RT сможет адекватно рассказать - это соответствует примерно тому что остается за пределами вейвлет-анализа), а затем и Direction поперевыбирайте. На разных фонах вы сможете увидеть на какие слои этот движок разложил изображение, где какие детали находятся и становится более ясной стратегия дальнейшей обработки фото.
    Далее - для работы с каждым уровнем имеются свои инструменты (без них ничего с фото не произойдет!!!)
    Для освоения - выберите один слой какой-нибудь и начните дергать ниже лежащие ползунки, вы увидите, что ползунки для этого слоя оказывают максимальное воздействие, ползунки для других слоев не оказывают практического воздействия. Почти к каждому ползунку там есть всплывающие подсказки - читайте!!!
    Все контрасты, шарпы и шумодавы там работают только при включенном вейвлете, степень задействования меняется прозрачностью для всей закладки в целом.
    Но что делать дальше? - изображение для одного уровня - мутная такая вещь. Надо снова вернуть Процесс на Все уровни во всех направлениях - картинка вернулась к обычному виду, но слои-левелсы никуда не делись, они "сидят" внутри инструмента, и с ними можно работать точно также, только теперь мы видим картинку в целом.
    Теперь можно приступить к "расцвечиванию" фото - большие цветовые пятна остались за пределами левелсов 1-9 и вошли в Остаточное изображение (Residual image). Идем к этому инстркменту (делаем его активным) и для начала покрутим хрому - возвращаем/добавляем сочность изображению- полезно для шумодавленных картинок, ну и пробуем освоить там и другие инструменты.
    С о временем-опытом лазить по слоям не станет необходимым, только иногда посмотреть - уточнить.
    Можно попробовать замутить обработку пары фото каких нибудь характерных.
    Skier нравится это.
  14. Skier
    Я ЗА!
    пойдёмте в профильную ветку, я там ссылку кину и покрутим.
  15. V_A_D
    V_A_D Новичок
    6 апр 2017
    День добрый! А не подскажете точнее где та самая галка?
  16. alex1974z
    alex1974z Старейшина
    19 июн 2013
  17. Nikkc
    Nikkc Старейшина
    4 окт 2014
    Петропавловск Казахстан
    у вас эта галочка стоит
  18. alex1974z
    19 июн 2013
    Yes, sir![emoji6]
    [emoji736] Использовать графический процессор, тогда фш будет использовать видеокарту[emoji482]
  19. V_A_D
    V_A_D Новичок
    6 апр 2017
    Спасибо, добрый человек!
  20. alex1974z
    19 июн 2013
    Не во что[emoji4]
